BONNET SPRING ???
Started by Blown_FC, October 12, 2004, 02:40:34 AM
Blown_FC
I'm chasing a bonnet spring assembly.....that is.....the spring with the pin and seats that hold the bonnet closed, not the hinge springs and not the bonnet catch lever.
Mine was buggered, so it was cut off with the angle grinder.
If you can help out, please reply.
Mark
leon
 :)G day Mark.
Try Slim I'm sure he would have one.
Regards. Leon ;)
robbzfc58
mark   ill have a look ..reckon i should be able to help ;D
robbzfc58
robbzfc58
sorry mark....all those parts are missing from the wreck
...keep searching
robbzfc58
#4
Just checked one of my wrecks, if I can get it off without busting it, it's yours.
Blown_FC
Thanks...much appreciated !
Mine was rusted at the nut inside the front of the bonnet.....just couldn't crack the nut without wrecking the slot at the top of the pin where he screwdriver goes !
Is there any specific torque settings you need or just whatever I can find  ?
Mark
Whatever you can find Mark, Ed is also going to send some stuff. So between the two of you I should be OK.
slim
Mark, I have this Spring Pin and retainer you require and have emailed you regarding it. Had to sacrifice a bonnet with the grinder to get it out for you though. Hows that for a Parts Supplier.!!!!!! Never mind ,, Now I only have 9 bonnets left... (lol)?
Im located at Liverpool, NSW
Blown_FC
Slim....your'e the man !
Still no email as yet...will keep checking !
Mark
