Front Brakes- Fitting of flexible brake hoses
Started by paddockbasher, October 08, 2004, 05:06:48 AM
paddockbasher
When reattaching the front flexible brake hose between the junction on subframe to the brake backing plate is  it necessary to bolt into backing plate first by turning the entire hose and then connecting at subframe junction?
With it connected at subframe when I try to bolt to backing plate the hose starts to twist/wind up. Unsure as to if it means the flexible pipes fittings are stuffed/seized or I am simply doing it incorrectly.
Any help much appreciated!
meeky
Either way will work.
If you attach at the subframe first by using the retaining clip, you have no option but to pull the brakes apart so you can unbolt the slave cylinder to turn it.
If you don't want to pull apart your brakes, attach to the slave cylinder and tighten, then connect to the brake line at the subframe connecting point and re-insert the retaining clip.
Either way you often end up having to twist the flexible hose up to a quarter of a turn to ensure a tight fit.
paddockbasher
