Which gearbox to use
Started by Kermit, September 28, 2004, 07:23:59 AM
Kermit
I am sure this has been covered before but as i am about to install a HR front end to my EK Ute i thought i might go a bit further and change the Gearbox to something more modern and something that "does not scream its lungs out on the freeway" I am keeping the grey motor so i would like comments  from the forum on what box they think i should go far incl model number if possible.  I know about the modifications i need to make i realy just need suggestions on which box
Rgds
Mick
oldgmh
#1
All 3 and 4 speed boxes have top gear as 1:1 ratio so there is no advantage in different boxes for highway driving.  Most 5 speed boxes have 5th as an overdrive gear which is good on the highway.  The other alternative is to change your diff to one with a different ratio  (3.55 or 3.36) or even go to 14 inch wheels.
earlee
jezz
on the topic of gearbox selection...
has anyone slotted a T700 auto into an FC?
I'm toying with the idea of swapping the top loader I've got behind the V8 for an auto.
Jezz
Burnsy
No idea Jezz but it sounds like a great idea, it would make cruizin a real pleasure in addition to removing some F&*$ contamination ;)
Mike
fastjbav6
Keep the Top Loader so the Mrs can't drive it  ;D
Seb
Yellow Knight
Spinner
Mick,
Wander into Dellows at Revesby and say: "I got an EK ute.  It has a Grey Motor.  I want overdrive.  Watchya got?"
Fly with what they say, even if you use their advice but not product.
Spineer
