A motor that will not stop.
Started by Vinnie, July 27, 2004, 08:00:25 AM
Vinnie
Guys ???
I have bought an FC ute with a 202 motor, problem is that when ignition is turned off, the motor seams to splutter rattle and keep running for a few seconds untill it eventually dies with a last groul splutter and cough.
I have tried timing it, but refuses to run on the rikter scale . Is running currently way below top dead center.
Any thoughts on the matter?
Vin :P
robbzfc58
vin   does it run ok if you adjust the timing , ignoring the timing marks... may be  the pully on the harmonic ballancer has spun
      trev
robbzfc58
ACE
Hi Vinnie,
Heres my guess if you've checked all the basics.
The outer pulley on the harmonic balancer has slipped. ;)
Regards ACE 8)
Vinnie
Thanx guys, will check out asap, will get back to ya!!! ;D
Vinnie
Hey
Checked the pulley, OK. Could it be that one of the valves be stuck or even a carbon build up inside the cylinder?
craiga
#5
Vinnie,
You should manually time the engine by finding TDC on Cylinder No1 compression stroke. At this point the marks on the harmonic balancer and the timing cover should line up, and your points should also just be about to open with the rotor approaching the No1 plug lead. This will always get it close enough to get you running, and will not rely on the harmonic balancer being accurate.
If the timing is fairly close and you still get run on, its usually a sign of either excess cylinder heat which ignites unburnt fuel in the cylinder, excess carbon build up which similarly continues to burn leftover fuel after the ignition source is removed, low compression, or a combination of all three.
You could try to use one of the aftermarket engine decoke mixtures, I'm not sure if you can still get Redex but this was always very good at removing carbon build up.
Good Luck.
Craig.
Vinnie
Thanks Craig,
As i have tried spraying water down the carby to try and clean up the cylinder, slight improvement must be on the right track, will try running cooler plugs in the last attempt to try resolve the problem as i am planning to take the head offfor a better clean and thorough cleaning. Hope my effort will not be in vain.
Will Advise
Vin
fastjbav6
Is it flooding after turning engine off?
Look down carby and see if fuel is dribbling down the throat.
Seb
Yellow Knight
Vinnie
Seb
Did not even think of that! thanks will check out prior to ripping the head off.
Vin :-[
fastjbav6
#9
Also is it idling too fast or the distributor base plate sticking causing the timing to advance?
Latter 202's (HX/Z) had a solenoid to close the throttle to prevent run on.
Seb
Yellow Knight
Vinnie
Hey
The run on was or as far as i know was that the engine was running a bit too hot. Changed the thermostat, flushed the system touch wood all is well for now.
Thanks guys for your help
Vin
