bosch heater
Started by Phantom, March 13, 2004, 10:31:24 AM
Phantom
G'day all,
                   This is the heater that was in the boot when i purchased my car, how do i mount it to the firewall, what type of hoses? do i need to hook it up to the demister vents and what type of switches do i need to turn it on and off ?  ???
                                             Cheers Rusty
Bogans rule
Phantom
Bogans rule
Phantom
sorry that the pics are so large but i am am a bit thick on the puter
Bogans rule
Rusty, the 2 captive nuts have a piece of "all thread" about 60 mm long threaded into them.
Holes are drilled in the firewall to match the all thread and to accomodate the hoses, then nuts are threaded onto the threads to hold the heater in place.
The switch is a 2 pole rheostat type with positive on one side and heater on the other, heater itself provides the earth to complete the circuit.
I guess you knew that your heater is missing the doors as well.
Hope this is clear
Phantom
Thamks for the info Ken, but as i don't know much about fc's YET ( i am learning fast) my heater is missing "doors" what doors? .
                                                   Cheers Rusty
Bogans rule
xALx
I think Ken means 2 flaps or doors on the bottom of the Heater (second pic) ..I might be wrong but I think they were meant so you can shut off flow to the floor and force it out of a duct towards the screen for demisting.
On the front of the heater you can see 2 clips which look like they don't do anything.  These originally held on the doors.
As xalx says they direct heat either outwards onto your feet or upwards onto the screen through the ducts to the demister vents.
Phantom
OK Ken next question , where do i get the "doors" from and what do i use for the demister ductsthet direct the warm air to the demister vents?
                      (do you have any?)
                                                        Cheers Rusty
Bogans rule
Rusty, unfortunately you will have to get doors from another donor heater, will keep a look out.
Re the ducts - r u good with fiberglass or metal fabrication?  The outlets you have on the heater must be transformed to a circular shape to go into the demister pipes.  You are welcome to look at the ones I have made on my heater if you like.
Regards  Ken
Sarge
Rusty
         Ed makes after market vents if you are interested. Look in Reproduction Parts/Sales
Mark
       0421 165 351
Phantom
Thanks Ken as usuall you are a wealth of information
                        Cheers Rusty(if u r taking your car to the next meeting at Shannons i will definetly be having a look)
Bogans rule
Phantom
Sarge, thanks for the info
                               Cheers Rusty
Bogans rule
robbzfc58
russ this is a nasco heater...similar to bosch
robbzfc58
Phantom
Thanks Trev
                          Cheers Rusty
Bogans rule
