LSD Centre
Started by Bates, September 18, 2003, 09:31:24 AM
Bates
Hi
I,ve got two Limited Slip diff centres to suit Fe up to Hr. One is perfect condition other is decent but has rust stains on gears. Both are 3.3 ratio. Asking $200 and $120 for the other.
If interested please ring 0413 773 747 or email me phone will be quicker
thanks
Bates
KEN
G'DAY BATES
I AM INTERESTED IN THE GOOD CENTRE,BUT WILL IT FIT INTO A STOCK FE BANJO ?
IT WAS GETTING A BIT LATE TO RING, SO I WILL RING YOU ON THURSDAY MORNING OR IF I FORGET YOU COULD RING ME ON 0404461260
IM ON THE CENTRAL COAST N.S.W.
                                                       THANKS......KEN
HARKO
A limited slip diff centre housing will have a threaded nut on the inside bottom of the housing,
 Rather than placing the centre over the stud as you would FE FC Type , You will have to weld into the housing a nut so you screw a bolt in through the housing rather than a nut on the stud.
Not sure if that makes sence , I correctly standed     :)
