accelerator linkage
Started by Brad, January 29, 2024, 09:37:21 PM
Brad
Hi all
      Just fitted the linkage to the firewall and the rod that goes from left to right seems to have a lot off play
      between the locating brackets.
      Is there a spring or something that fits to the end of the linkage rod to take up the play?
      I sort of remember that a small spring and washer was on the left hand side.
      my memory's not to good as it was 35 years ago when I unbolted it
      If not than I might put a couple of felt washers in there to compensate .
              Thanks again Brad.
There is a factory spring Brad, on the drivers side from memory. I’m running a c@blend clutch so from memory.
From memory I took these from the FB/EK Workshop Manual but they may help.
DougT
Hi Brad, on the right-hand side (driver's side) there should be a coil spring in between the mounting bracket and the cross shaft that takes up any movement in the cross shaft.
Doug
Brad
Thanks all for the replies.
              I thought there was was a spring on the shaft . Now all I have to do is find one :D
                     Brad.
