Reinstalling the bonnet emblem
Started by Laszlo, May 21, 2021, 07:31:42 PM
Laszlo
Hi everyone!
I'm having a trouble to putting back the bonnet emblem. I can't see how can be done  keeping the plastic insert in the right spot and the same time put the holding bolts through the bonnet holes?
Even with a helping hand looks extremely hard.
Any advice appreciated.
Laszlo
Holden = The Heartbeat of Australia
Laszlo
The puzzle....
Sent from my SM-G965F using Tapatalk
There are 2 clips that hold the plastic emblem in place on the back of the metal piece from memory.
DougT
I am pretty sure you are missing the two threaded rods that screw into the threaded holes on either side of the emblem. Once they are in place the retaining plates (shown in your picture) are placed over them and secured with nuts, this holds the emblem in place. The threaded rods need to be long enough to protrude through the bonnet in order to secure the assembly to the bonnet using two additional nuts. Hope this makes sense. Regards Doug
Stewy
This should show what you need. :)
Cheers Stewy  8)
Laszlo
Thanks guys  !
Yes, make sense.
Now I can sleep tonight  !
Cheers :  Laszlo
Sheriff
Gday Lazlo,  any chance you can pull out your front bolt from the bonnet bird and let me know how long it is.?  thanks,    Mike.
Laszlo
G'day Mark !
I did measure it,  I'm using 15 mm stainless steel 1/4" Philips head bolt. I think the thread in the hole is 20 mm.
I don't know the measurements for the original bolt
In the second hole at the back of the ornament if I'm right you can use maximum 15 mm bolt. Otherwise  lots of  washers.....
Cheers  : Laszlo
Laszlo
Everything is back in place, thanks guys !
Laszlo
Beautiful Laszlo
Stewy
It is such a nice touch.
You have to love an FE bonnet emblem.
Cheers Stewy  8)
Stand up and put your chest right out son ,...Vern
Sheriff
Thanks Laszlo.   I think you must mean 15cm for the front bolt.??  I thought from memory of the ones that were lost by the platers  it was about 4 inches - 10cm long, to go through the panel in front of the bonnet catch spring/bolt.  I have bought some stainless 1/4inch bolts but still working on marking out where to drill the holes.   I have the plan from on here, just measuring a few times before taking the plunge and drilling.  cheers, Mike.
Stewy
Hi Mike,
This is the length you need.
Cheers Stewy   8)
Sheriff
Laszlo
Ok, an other puzzle solved.
Anyway I used only 15mm ( not cm) 1/4" stainless  steel  Philips head srew at the front. And a skinny screwdriver what I put through the  hole was already there and a bit of juggling  (a couple minutes) and the bird was perfectly secured. If you do it  Mike's way you are saving a few minutes fun to finding the head of the srew with the screwdriver.😁
So how I done it the srew just vent through one layer of metal, the top of the bonnet. (I hope I didn't over explain myself ....)
Laszlo
