Oil pressure gauge
Started by Wookie 66, May 05, 2021, 06:27:29 AM
Wookie 66
Good morning all
Is it possible to retain the original oil warning light and fit an after market oil pressure gauge,
I spy a small plug towards the front of the block that the new gauge fitting will fit
Will that work or do I have use the original sender unit spot? Hope this makes sense
Usually you just get a tee adapter
Fraze
The small plug near the fuel pump goes nowhere. When you have an accessory oil filter fitted, the return line is fitted there, to return oil to the sump. For the pressure guage, fit a "T" at the oil pressure sender fitting. Cheers, Fraze
Quote from: Fraze on May 05, 2021, 08:06:02 AMThe small plug near the fuel pump goes nowhere.
From memory, that line of slotted-head plugs are on the cam oil feed gallery.
Wookie 66
Thanks for the info
Where might one get the T adaptor from ?
Local speed shop
Wookie 66
Thanks every one all good autobarn had it stock
Good to know. There may actually be hope for the world yet. 8)
