Wanting to buy 2 Front end springs FE Fc Fb EK
Started by HoldenFE, December 01, 2020, 07:21:05 PM
HoldenFE
Wanting to buy 2 second hand springs to suit FE to Ek front end.
I am in Narre Warren and can pick up
Thank you
There will be a part no stamped into the flat part of your existing front coil springs
They are all slightly different, even between FE & FC models
I have a few pairs of front springs, from memory I have a sedan set and a wagon set but would have to check the part numbers. I’m in Hoppers Crossing.
HoldenFE
Thanks for the reply gents. Did not realise that they were all different. My problem is the front end does not have the springs fitted but the front end is off an EK. Any thoughts?
I think EK front springs are slightly thicker, you could try Kings Springs, I think rare spares sell them?
I put new King springs in my FC special sedan , shopped around and got best deal at Bursons ,dont forget to put the anti squeek rings under the coil in the lower control arm..which come in the box...cheers Vern .
