Under Dash Brake Booster
Started by Mal W, March 23, 2020, 09:43:18 AM
Mal W
Hi all, is there anyone here that has fitted an under dash booster to their FE or FC.
I fitted one to my 57 chev by using a Toyota HiAce booster and that worked great and was just wondering if anyone has done similar to an FC and if so what pedal setup did they use.
Mal
Malcolm WHITTAKER
Mal ..I restored a Hillman Hunter few years back ,the Lockheed booster was totally stuffed ,Steve at B and R brakes said he could fit a VH44 in same spot ,or if I wanted a smaller compact booster under the guard ,with a mud and water cover .just 2 lines coming in thru inner guard, I can't see why that wouldn't work for a FE or FC ..Vern ..
