Front Bumper Bar - curved or straight?
Started by oldgrey58, July 09, 2019, 02:04:07 PM
oldgrey58
Hi all,
Is the middle section of the front bumper bar straight or curved to match the curve of the splash panel under the front grill? When you are looking down from above.
I've just fitted my front bumper bar and it's relatively straight. Is this because after 60 years its been massaged/bumped into being straight or is it supposed to be that way instead of having a curve that matches the curve of the splash panel across its width?
The rear edge of the centre bar section may be quite straight, and may not follow the curve of the panel immediately behind.  But if you look at the fold line and the front of the centre bar section, they will in general follow the curve of the panel behind.  I think this is because the centre bar section does double duty on the rear bumper as well, and the rear end bodywork has a much less-pronounced curve than the front.
Not to mention Rob, that the same pressing also saw duty on front and rear fb and ek bars. The general sure got some value out of that set of tooling. We must be talking roughly half a million units allowing for commercials.
I measured a couple of pieces I have. They both curve 8.5mm at centre.
Clay
oldgrey58
Thanks everyone for the replies. Seems my centre section will need some work to get a curve in it. I also compared it to the rear bar and it was similar but a bit flatter. I'll also shop around to see whats available.
