FE Sedan Jack
Started by JohnBM, August 26, 2017, 07:43:12 PM
JohnBM
Can someone please clarify which type of jack came with the FE Sedan from the factory? I have been told bottle-type is for commercial vehicles and scissor-type for sedans. Which is correct so I can sleep tonight
KFH
My understanding is that it was a scissor jack supplied with the FE/FC and the bottle jack was standard supply with the utility and maybe? with the wagon.
Scissor jack requires the pressed support bracket fitted to sedans and I believe wagons adjacent the b-pillar between inner sill and floor. Enables lifting the entire sprung side of the car, which requires a fair lift to get the wheels off the ground. The commercials don't have these brackets so a bottle jack has to be used under the suspension. I assume GMH was expecting commercials to be potentially fully laden and too much weight to rely on supporting half the vehicle on one relatively flimsy point. Whereas any passengers would be expected to alight from the vehicle while the flat tyre was changed with the spare.
Clay
The FE FC scissor Jack is a bit of a rare item, it was weak in costruction and was superseded in the FB by a better scissor Jack with a ratchet handle.
This jack ran for a long time (about HR) and is easy to find and identify as it has a distinctive yellow decal on it with a pic of an FB on it.
The FE FC Jack is painted engine grey and has a small rectangular decal. It's most distinctive feature is that is has a T drive head and is a one piece handle unlike the bottle Jack which has a 2 piece handle and a square drive.
JohnBM
Ken, It would seem I have one of the rare ones, which came with the car. It is as you described it, the warning decal for its use also has the manufacturers name on it which was W. H. Wylie & Co Ltd from Hilton South Aust and the handle is one piece
Spot on John, that's the one
Ken's 57
Where exactly was the jack and handle stored in FE/FC sedans?
Cheers, Ken  ???
KFH
John.  Could you please post a picture of the jscj and handle.
ACT59FC
See attached pic of FC sedan Jack and tool kit from master parts book. I got these pics from Ken.
As far as I can see, the jack and handle sits best tucked in behind the spare wheel. Because of not wanting to scratch paint etc, I usually wrap the jack and handle in a piece of cloth.
It does fit down in the quarter panel well, but I don't like the idea of getting some unintended dents in the rear quarter panel :o
Ken's 57
Thanks Ken. I agree about the potential for dents. I've been storing mine behind the spare as well but was just curious as to where they were placed when leaving the factory.
Cheers, Ken
I've not seen any photos that show the jack as stored from the factory.
