bottom radiator hose
Started by slack one, July 28, 2017, 12:53:05 PM
slack one
Hi all can anybody help please. When i put the vr v6 commodore engine in my fc and i am using original radiator what bottom radiator hose do i need to use. If possible i don't want to use a custom radiator. Do i have to have the bottom hose outlet move to the right hand side if so what would cost roughly be.Thanks Gazza.
Both my 1948 Vauxhalls run V6 . Both run radiators out of early Hilux , the convertible runs series 1 and the coupe a series 2 and they both now have adjustable thermostats on the radiator hoses as well as lower rated thermostats in place of the hotter originals . You can get the stainless pipe that brings the water from the rear of the head to the radiator from a series 1 ,and then cut a sleeve to join two hoses . I only do this because it is easier to put the thermostat sender in, and easier to find hoses . Just an idea for you to play with , and by the way the temperature switch is only an earth so you can over-ride the switch with the variable thermostat and a toggle switch that lights on your dash as a fail safe . Cheers Haydn
slack one
Hi all i am going to see my local radiator guy tomorrow and see what he says. Cheers Gazza.
riger45
Quote from: slack one on July 30, 2017, 04:18:09 PM
Any update on the radiator hose? We might be needing a bottom radiator hose as well. We'll be working on the fc right after we finished installing the new Toyo tires on the current pick up project.
slack one
Hi rigger45 I went up to the exhaust place and brought two pieces of round pipe one the size of the outlet on the radiator which is a small outlet the other piece that fits the engine hose is bigger the guy at the exhaust center shrank the bigger pipe to fit the smaller pipe and i mig welded the two together. I brought a bottom hose for a holden Astra  it is shape like a S which is the same size as a early holden hose. I cut the hose so it looked like a L shape one end fits the bottom radiator outlet  and the other end fits the small end of the tube. I had a flexible hose the fitted between the other end of the pipe and onto the engine. The pipe is about 300ml long. I will put a photo up soon i hope this helps. Cheers Gazza.
