Dakota Digital Gauges
Started by pop, April 09, 2017, 08:00:23 PM
pop
 Hi guys, I'm searching around for a set of digital analog gauges, and set that l like are Dakota digital analog 57 Chev VHX series.
    The problem is that there advertise the diameter of the speedo gauge as 6.25in and l think, just to big for me for the fc dash.
     I've also looked at classic instruments, there gauge is 4 5/8in but l don't like the face set up, Auto-meter has a 3 3/8 speedo,
     but the face is to small for what l want, and yes, l do realize that bezels are different sizes, and l can spin my own.
     What I'm trying to find is....and l know it's probably impossible, without custom order,.... $$$$
      1.4 5/8 to 5'' with half sweep speedo at top, with tacho & fuel at the bottom, and a gear selector etc. readout in the middle
          with warring lights.
      2. 2 1/16 oil gauge plus a 2 1/16 temp gauge
     So my questions are.....
      1. Has anyone used this dakota digital 57 set up or any other gauges from them, if so, how'd they fit? Any problems?
      2. Actual gauge sizes & cut out without bezel
      3. What other digital analog gauges are everyone else using?
      4. Any other idea's and pic's would be greatly appreciated, and I'm really trying hard to  keep a bit of originality
          In advance, thanks to every ones comments........pop.
pop
  hi guys,
    would like to give ya's an update,
      After talking to Dak/dig they asked me send my dash pannel and they mite be able to do somthing.....usa sorry, and arrogant.
      Autometer wasn't as bad, they have an online customshop, which is great, for sorting out the look, colors, pointers, bezels, font, etc.
      problem was that they couldn't change the speedo size, even though they advertise it else where. After emails etc, please try again.....
      Plus they could not add warning lights, turn signals or high beam which means more clutter and wiring, more $$$ etc.
      So...After months of brain drain, Classic Instruments have all the above, nearly, just trying to change the dial face colors at the moment.
      And Yes..There going to cost a hell of a lot. But compered to rest of the build it will be worth it.
      Thanks for everyone looken, but this mite help someone else.
               Cheers POP.
fastjbav6
Good to see you got a result in the end.
Regards Seb
Yellow Knight
Hi POP are you getting the oil gauge and amps gauge done as well? Will the speedo be in km/hour?
Would love to have an estimate of what you are paying.
Great stuff thanks for posting.
Wayne b
Hi Pop, have you looked at the VHX1016 series gauges? I am in the process of modifying my dash to fit the unit in and still have the switches in place all be it in vertical rather than horizontal layout.
pop
  G'day guys, a bit more
     Thanks to everyone for looking and your replies. To start... thank you Seb. Wayne b yes & yes to your questions. Jim, they are the the first ones that I looked at, but after blowing up the image to full size and laying it on my dash, plus no warning lights, they wher'nt for me. That's when I went hunting, as above.
      So this is what I came up with from Classic Insturments.  Hot Rod Series gauges.
      4 5/8 combo Speedtachular HR50SLF + extra KPH, with turn, high beam + extra LEDHTH, plus speedo sending unit extra SN16C
    The other 2 1/8 gauges are full sweep and have built in warning lights, that light the gauge red when somethings wrong. Plus senders
      Fuel HR109SLF ( programmable)
      WaterTemp HR126SLF
      Oil HR181SLF
      Volts HR130SLF
    With all upgrades, plus red pointers, burgundy ring and postage.......sit down,   $2500.00
    But with all the new Customs Import Duties, US Dollar etc. & not have a cluttered dash, I'm Happy.
    There is a standard kit without all the bells & whistles HR65SLF approx $1350.00
      Thanks again guys, any other questions or info, would be glad to help if I can.
       Regards  POP.
Hi POP any photo's yet?
Wayne b
old-blu
 I used Dakota Digital Gauges in my Modified ute.  I modified the dash panel to suit the gauge sizes they offer. I extended the LHS of the panel so that the gauges sat in front of the Driver [to fit well with the Bluebird column I used].  The digital gauges need to be recessed into the dash panel, extra tinting on windows & a front sun- visor,[if you can find one], so that you can read them during daylight hours. They are clearly visible @ night etc. Would I use them again? NO WAY!!   It took 8 months to get the dash panel back from the USA. John Rapinette fitted excellent gauges to his Modified Sedan, which look the part & ones I would have used , with the vision of that great commodity called "Hindsight". Good luck with your decision. Kevin.
6th, may 1958 "I was there".
Some of these problems just need some thought and a little talent and they are solvable . I know I sound arrogant .I am just saying that I have been around for quite a while and have seen a few tricks .
old-blu
Oops!  After slapping myself on the wrist, no further comment required.
I used Speedhut gauges in my EK Ute project not cheap but they have a great range and are customisable.
Neil
