Sandblasters
Started by Not Happy Jan, October 03, 2016, 04:33:02 PM
Not Happy Jan
Thinking of getting a sandblaster for all the little fiddly bits. What have You guys got at home and how much do they cost for a good one
You can never have too many!
Port Macquarie NSW
What size compressor do you have ?
The supercheap style ones work ok
But you need a really fine mesh to stop chunks going into your garnet.
Also a old vaccum or dust extractor is needed.
My old one i had a tungsten nozzle but our new one is a big abs 15k pressure one.
camxsmith
HI
   I have a Supercheap blaster, which I was lucky enough to get at %50 off. I agree with Pete with requiring a vacuum of some sort. I added a vac port on the back and added two extra lid handles to help squeeze the back down as it leaked a bit. I have been able to do a lot of parts with good results. One let down in long parts will not fit. I also use some book covering clear plastic on the inside lid. As you soon go through the ones provided. And I find the light on the inside a waste of time as it is not bright enough. Still recommend it tho.
http://www.supercheapauto.com.au/Product/SCA-Tabletop-Sandblasting-Cabinet/285583
