Steering Wheel Puller
Started by ekute, May 21, 2014, 05:09:55 PM
ekute
Does anybody have one to suit FE wheel that they would like to lend/hire?
brett_f
ekute,
I dont have one mate but if you go to do the "wiggle and pull" method on the steering wheel, make sure you put the nut on part way to stop the steering wheel hitting you in the face. regards Brett
Maco
Quote from: brett_f on May 21, 2014, 07:38:50 PM
ekute,
Hi Brett,
I have one you can borrow.
Better in Green
brett_f
Hi John, I think your replying to ekute but thanks anyway. brett
..... make sure you put the nut on part way to stop the steering wheel hitting you in the face ....
Yep, did this without the nut about 30 years ago & have never forgotten the smack in the nose.
ekute
Stewy
I bought one of those generic universal type pullers (about $20) and just slightly modified the heads of the bolts to fit in the holes and this worked perfectly. Have used it several times since.
Cheers Stewy   8)
