Diff ?
Started by surferboy, May 19, 2014, 04:55:10 PM
surferboy
What have I got under the wagon ?
FC diff ?
cruisin's great with a 58
surferboy
Brakes ?
Stewy
Looks like FC to me.(original bump stops on the wheel arches)
But I am no expert  :)
Cheers Stewy   8)
philwreck
housing and brakes appear fc diff is later model evident by u/bolts on t/shaft .thus  you  would have better ratio,you can check ratio by looking on dust cover behind diff yolk.should be small stamped imprint.
its a short bolt so can only be 3.55 or 3.36 (theres also a torana 3.89 with u bolts but i highlly doubt its one)
GOA350
It's FC, you can tell by the wheel cylinders and the size of the brake fluid pipe on the diff.
