Original wiring
Started by hsv-001, September 10, 2013, 06:48:08 PM
A few weeks ago I install new relays to boost my h4 headlights. Being rather unmotivated I simply cut into the existing wires at the left junction block and put in  high and low beam relays and ran wires across to the right junction block and disconnected the original wires there. So the rest of the harness still looks the part, the relays look out of place so I was considering gutting a regulator and hiding the relays inside . I was wondering if anyone has done this, just a thought.
Sparkie
hi ,your idea sounds like it would look very neat, I put my relays on the outside of inner guard and kept the terminal blocks .I also fitted extra relays there for thermo fan and air horns,Gary
