Rear inertia seat belt mounting points
Started by FC 304 wannabe, February 23, 2013, 07:48:14 PM
FC 304 wannabe
Quick question...
When mounting inertia lap sash belts in the back.
( rear top of parcel tray) where are  the best mounting points located???
brett_f
I have mine located in the far corners. Must have plates underneath to support them. Also remember the plates must not have corners as the engineers wont accept them (most) as they say they will act ike a can opener. This also relates to all other plates used for the seat belts.
Brett
FC 304 wannabe
Thanks Brett.
Do I mount the bottom anchor points to the wheel arch , or the floor ??
I'm leaning towards the wheel arch just below the seat line... ???
The wheel arches are best, this keeps the belt in tight against the arch. Later Holdens which had seat belt points fitted from the factory use the spot exactly as you describe.
