Rear Sway bars
Started by Not Happy Jan, August 24, 2011, 09:22:51 PM
Not Happy Jan
Just wanting to know if rear sway bars can still be purchased? and can they fit a wagon??
Nick
You can never have too many!
Port Macquarie NSW
Anything can be made to fit i have seen a few commodore ones fitted with some moded bracketry ???
2door350
I used a selby HR one from memory - i was quite beefy, maybe 20 odd mm, i put some right angle brackets on the frame rails in front of rear wheels and mounted it to them.....not too difficult, mind you i have since taken it back off and prefer the ride without it...i would use a very small one if i tried another
2door350
I ripped holes in my rails when i had a HR one on there ??? just get a decent shock over a sway bar i reckon?
perth_ute
I bought front and rear from whiteline suspension. The result is amazing very stiff. They come with a mounting kit. I think the rear is 20mm and front is 28mm anyway the website tells you it all.
Not Happy Jan
Thanks All
Might just get a good set of shocks as you say Pete
Port Macquarie NSW
I ended up taking my rear sway bar out as our roads are horrible and it just made the ride rougher but when i fitted a good set of shocks i ended up cracking the top shock mount.. >:(
