Engines
Started by Gordon, November 08, 2010, 08:25:29 PM
Gordon
Hi can i put any early model holden six (186-202 red blue black) in the fc without any chassis kits or major changes or engineeres cert? and register easily? Am fitting HR disc brake front end ,vn rear
Thanks Gordon
 You Don't need a chassis kit but will still need it to be engineered rego is pretty easy ......FC427.......
GMHwagoon
gordon dont know what NSW rta are like but l had mine engineered and regoed in victoria
hr disc brake front end 186 red motor , all l needed was a two speed wiper motor retractable seat belts front and rear
no rust and all the other normal roadworthy stuff   $500 for the engineer
Gordon
Hi what seat belts did you fit and how?
Gordon
ratbox
in NSW you can put a 138 red motor or a 149 red motor (if you can find one) without engineers report, BUT you will need an engineers report for the disc brake front so you might aswell do the bit extra work and engineer the engine aswell in theory you would need the report to cover the diff aswell
another thing if you go with a 202 aswell as the usual stuff for the engineers report you will also need dual circuit brakes and a collapsable steering collum from most if not all engineers
Quote from: ratbox on November 09, 2010, 09:54:46 AM
If you go over 200 cubic inch you will need to fit the dual circuit brakes and the collapsible column. Keep it under 200 cubic inch and there's no problem
F4+ ;)
Also heater demister ..
Gordon
Hi understand everything so far, brakes,seat belts ,engine size,steering column,But the heater demister can you buy an after market one to fit ?
Thanks Gordon
in NSW you can put a 138 red motor or a 149 red motor (if you can find one) I have a  NOS 138 block with pistons still in the wax paper and the GMH crate that if someone was interested in could make me an offer by [PM] .......FC427.....
My mate ran a 12 volt hair dryer from a camping shop with 3 speeds to pass rego in his t model rat rod dont know how long it would last but gets the heat up there pretty quick. he just bought that flexi steel piping and put it over the nozzle.
But any good hot rod shop or american auto parts should be able to get something.
