fc wagon tailgats skin
Started by GMHwagoon, August 06, 2010, 03:15:15 PM
GMHwagoon
can someone tell me if the outer skins for fc wagon the same as ute panel van
craig in queensland who makes these is not sure himself, thanks greg
Bob_FC_Ute
The differences between the Ute and wagon tail gate skins are the wagon skin has a hole for the handle and the major difference is at the top of the tail gate where it meets the rear window.
The Ute skin comes in towards the front of the vehicle a lot further than the wagon.
You could always use the bottom half of the skin that Craig makes or modify the skin to suit it would depend on whether you are doing a rust repair (usually at the bottom) or panel damage.
Bob
GMHwagoon
thanks bob l was hoping to put a full skin on
lot easier when repairing
thanks again
Jonno
vans and wagons also have a raised profile for the rear badge whereas utes do not appear to. See discussion here (especially down the bottom of the page):
http://fefcholden.org.au/forum/index.php/topic,7724.0.html
I would guess that new skins also do not have this raised profile so you may need to weld one in from a wagon.
Jonno
Cottles Bridge, VIC
