Rear body to bumper seal available
Started by Maco, December 05, 2009, 11:40:40 AM
Maco
Have stock if any one is after a set.
Better in Green
Wasim
Hello,
         I'd like a set please?
Regards, Wasim (Tony)
South Australia
Maco
Better in Green
necrotiki
hi there,
if you have any sets left I would like one please.
Maco
Quote from: necrotiki on January 19, 2016, 08:57:57 PM
hi there,
Hi, you have a PM.
Better in Green
robbo
Quote from: Maco on February 03, 2015, 03:45:27 PM
Hi John, I was wondering if these would fit my FB sedan ?
Cheers Rob
John i need another set for my ute can you PM me details
Maco
Better in Green
Would like a pair for my EK van please John. Please advise if available and pm cost and eft details.
Clay
Maco
Quote from: Errol62 on July 15, 2016, 07:59:24 PM
Clay
Hi Clay,
I am not sure if they fit  an EK van, maybe someone can check there parts book, thanks in advance.
Better in Green
Hi john
From the photos they are identical. I have an original pair which are a bit withered. The commercials are the same fe to EK.
Cheers clay
Maco
Quote from: Errol62 on July 15, 2016, 08:59:42 PM
Hi john
Cheers clay
Hi Errol,
I have sent your a PM.
Better in Green
Stewy
FE/FC sedans and wagons # LH 7411557 #RH 7411558
FB/EK sedans and wagons # LH 7412789  #RH 7412790
FE/FC, FB/EK utes and vans  #LH 7411769  #RH 7411768
So would depend how different they were if they could be modified or not.
I have a set of John's wonderful reproductions here in Adelaide if you want to check them for yourself first.
Cheers Stewy   8)
Maco
I know they fit FE, FC utes & vans.
Better in Green
G'day John,
I've been wondering whether these would fit an FB/EK too. I'm in the process of screwing together an EK wagon, and would like to give them a go. I'll take some pictures to show if they work or not.
Can you please PM me some bank details and I'll transfer some cash.
Thanks Stewy for the kind offer. I will take you up on it when I get back from Melbourne next week.
I seem to have thrown the cat amongst the pigeons here. Don't mind stimulating a bit of debate now and then. My supposition that they would fit FB EK commercials is based on their lower rear quarters being pretty well identical to the FE FC ones. This doesn't apply to the sedans and wagons of course with their definitive chrome fins so good luck with that one Harv.
Thanks for the info John and I will let you know once I get back and check with Stewy. Interesting that the part numbers are different and a good point but not really surprising.
Cheers all
Clay
Maco
Quote from: Harv on July 16, 2016, 06:21:37 AM
G'day John,
Hi Harv,
Thanks for your message, I have sent you a PM.
Better in Green
On an FB EK sedan or wagon - doesn't the rubber clip into the bottom of the tail light body?
I think the reason for the part number change between FE FC sedan/wagon and ute/van is because of a slightly different shape where it negotiates the bumper bar bracket.
From memory the ute and van rubber is a little shorter than the sedan wagon one.
Maco
Quote from: mcl1959 on July 16, 2016, 10:00:33 AM
Hi Ken, thanks for your comments, yes I believe the ute & Van are a little shorter & some members have trimmed them down, I believe the pinch mounting is the same. The FB/EK Sedan is different.
Better in Green
Yep, the mounting for EK is different, so expecting a bit of fit-and-fiddle on this one. Looks like a good product to start with though. I'll take some photos as I go.
