Gearbox issues
Started by ownfc59, May 26, 2009, 10:46:57 AM
ownfc59
Hi,
Just seeking some advice regarding a problem with the gears in my FC.
We have lost reverse & the other gears dont appear to be where they used to be on the column shift.  Also, the position of the end of the shifter is now much closer to the steering wheel than usual & it's difficult to go from 1st to 2nd gear (or at least where 1st & 2nd used to be).
I've had a look at the linkages where they come out of the steering column in the engine bay and they are very loose with heaps of play in them.  I'm thinking this isn't how things should be.  The locknuts on the gearshift rod are not tight and I am thinking there should be a spring in place to tension everything but I couldn't see one.  The diagram in the workshop manual shows a spring which appears to be tensioning the whole selector lever, this may be missing.
Any advice on how to diagnose the exact problem & possible fixes would be appreciated as always.
Thanks,
colt
It's possible that you have broken the bracket on the shift tube. This is up the top where your shift lever goes into the column. Your sloppy shift rods won't be helping either.
Have you got access to someone who can help? ie: where are you?
Colin.
colt
Yep sounds like broken shifter tube to me as well - very common. You will need to pull the wheel off to totally confirm.
ownfc59
Thanks Colin & Ken,
I started to dismantle the steering column on the weekend but came to a grinding halt as I don't have a wheel puller & that sucker was really on there tight.
I am in Toowoomba & could enlist the services of another forum member (Sherriff) but would need to get hold of a wheel puller.
The other problem is that the mighty FC has become my wife's daily driver since we sold our Corolla so don't get much chance to work on it.
If it is the shifter tube, how hard is it to find a replacement part or parts & could a relative mechanical dunce like me handle the job or am I better taking it to a pro?  Likely cost anyone?
Advice is much appreciated as always.
I have a few spare ones - $20 each
The hardest bit is undoing the bolt which holds the selector on at the bottom. Better to have a helper who is pushing down on the tube while you undo.
That is it is the hardest thing once you get the wheel off :-\
You could try other methods such as hitting the centre with a hammer (leave a nut on to protect the thread) whilst pulling up on the wheel.
ownfc59
Thanks Ken,
Having no idea what the part looks like, is it something that can be sent through Australia Post?
I'll try & get a look at it over the weekend to confirm this is the problem & get back to you.
Yes can be sent through Aust post
ownfc59
Hi Ken,
PM sent.
Regards,
Peter
FC0058
Harry Brazier (QLD Club Member) Also lives up on top of the mountain, I am sure if you give him a call he will be only to willing to give you a hand and some advice. I do not have his number but you should be able to find it in the book. He has his own electrical business in Toowoomba.
Cheers Jim
