Best grey
Started by jasonr70002, May 26, 2009, 09:39:07 AM
jasonr70002
Hey all I am new to grey engines which type/size etc is the best or are they all the same.
cheers Jason
Golden Holdens FE-FC
In regards to the grey, the early type had two welch plugs, the later type had three. All grey motors to the end of FC had a 3.00" bore. From FB on they had a 3.062. If you are going to bore them out I would use an EJ block as by then GMH had the castings pretty good and there wasn't much core shift allowing them to be bored to 3.250. I wouldn't bore them that much now, unless you intended on resleeving the bore
If you are looking for originality and have and an FE or FC then you would need an engine block with with and "L" prefix. If you were able to supply a Chassis number then either Ken or one of the other number collectors would be able to give you an idea of what your engine number should be if you wanted to try and find an engine number that is close to the production of the car.
I hope that this has helped.
F4+ ;)
Perce1
Just an add on here Jason & Keith. I am restoring a 59 FC holden that has obviously had an engine tranplant at some stage. Engine no is; CB165233 if any of the number collectors out there can shed any light on what this motor was out of it would be appreciated. It is currently painted red, but is deff a 138 as it is embossed on the side of the block.
Cheers Perce
Perce,
What you've got there is a 2250, or 138 red motor, as fitted to an LC or LJ Torana. That explains the colour :-\
CB engine prefix is the high-compression version. There was also a low-comp variant, its prefix is CC.
Grey motors have the GMH circular logo embossed in the side of the block, not their size. There are other differences as well, such as a single pushrod sideplate (reds have two sideplates), location of the distributor, 4 engine mounts (greys have 3) and many more.
Probably not what you wanted to hear, sorry.
Perce1
Probably not the ideal answer I was looking for ret, but will possibly use the motor until such time that I can get hold of a proper grey motor & do a rebuild.
Great forum here guys & apreciate all the positve help etc
Cheers Perce
