Seat surround handle
Started by NES304, May 14, 2009, 04:44:21 PM
Any one know how to remove this so I can fit my new seat surrounds?
There should be a grub screw holding it on.
FX1975
There is a grub screw holding it on from underneath
oldgmh
there is a small screw with an allan key head located underneath the handle.   :o :o
Underneath the handle,there should be a small grub screw with an Allen key head holding it onto the shaft....What the hell,everone else has had a go...  ??? ;D
OK  ;D ;D There is a small allen head grub screw located under the seat adjustment knob just undo this and it should come of .......FC427.....Bah Bah
Damo58
 ;D ;D iam not sure but i think there is a small grub screw with an allen key head on it  ;D ;D
Iam good just ask me :)
So I'm guessing its some kind of alen key grub screw?????
Pissin myself laughing.....
Get a big claw hammer and lever it off.
Before you put it back on, you will have to turn it over and loosen the small grub screw.
If all else fails you could get the oxy out, heat it till it glows bright red, this will allow the know to expand enough to release from the seat lever, (will more than likely set fire to the seat) Better to remove the seat as you don't want your car to catch fire.
Once off, cool, then loosen grub screw for reinstallation.
(May as well get it rechromed too as there won't be any chrome left on it)
;D ;D
F4+ ;)
ridgey_didge
I've always done it this way -
1.  Hold the allen key in a vice attached to work bench.
2.  Place the grub screw in the seat handle on allen key* and turn as far as possible.
3.  Lift screw off allen key, rotate the job and repeat step 2.
4.  Keep repeating step 3 as many times as necessary.
To reinstall do these steps in reverse.
*  Removal of the seat from the car first is entirely optional. ;)
David
Johns
That's all Ok, but how do you get the one on the passengers side off ???
Paul In Ireland
Well, first of all get an allen key.....  ;D
ridgey_didge
Quotehow do you get the one on the passengers side off
You need an allen key that turns in the other direction for that side.
F4+ ;)
oldgmh
Come on guys - stop taking the piss out of the bloke - all he wants to do is remove his knob.   ::) ::)
The correct way to do it is :
pull it very hard ( maybe a couple of pulls ) and you should feel it when it happen and releases..... so keep pulling until it happens ... :o :o
colt
Don't forget to cough as you pull on your little Allen Key. It'll come easier.
colt
Do I dare ask for the placement of the little black foam pieces that comes with the kit?
oldgmh
