accelarator pedal
Started by ashfe, April 08, 2009, 03:50:03 PM
ashfe
does anyone have a diagram of how the accelarator pedal mechanism joins from the pedal to the arm thaat goes behind the rocker cover as mine is completally pulled apart i have worked out from the carby to the arm but dont know what i need to join the pedal to it
FX1975
It is just a rod with clips on it that link the pedal to the control arm, pm me your email address and I'll send you a pick
                                                        Frank
There is a transfer mechanism half way along.
Rod from accelerator to transfer plus 2 clips
Rod from transfer to shaft behind rocker cover plus 2 clips.
I can supply all these parts if you need them
plumer46
Hi Ken and ashfe
I am in a similar position with my FE Ute, do you have enough parts for ashfe and myself.
John G
Yes - I will send you a pm
