v8 into fc
Started by pete, December 12, 2002, 11:46:09 AM
pete
Hi fella's has anyone out there got any info on v8's into fc or any pics at all
FC-V8
Hi Pete
       In the photo section there is some good photos of fe/fc's being modified with holden v8(ED'S WAGON)commordore v6 (JASON'S VAN & SGO'S SEDAN) & chev v8(MY WAGON).
       Attempting these type of modifications is a slow & exspensive process but if you have the skills to do the majority of the mod's yourself the more money you can spend elsewhere on the car.
       Have a look at the photos & I know the people on this site will do their best to answer any questions you have.
Glenn
0401-065-201
pete
Thanks for that info ,very good pics. Need some info on the chassis rails,( home made or brought) any info muchly appreciated.  Cheers.
FC-V8
Hi Pete
       The kit that i am using are from Castlemaine rod shop in Victoria. It included the chassis rails with gear box crossmember,tailshaft catcher & plates that are welded to the underside of the front chassis, modified HR front crossmember with the engine mounts welded on to suit the v8, Extractors, Shortend LH rack & pinion steering with modified HR steering arms,tranmisson tunnel.
Glenn
0401-065-201
sgo
There is a thread in here, 3/4 chassis in ute, that should answer your questions.
pete
Thanks again for the info. I've got an FC wagon and want to drop in an 8 and so far have found all these pics and info very helpfull ,so thanks guys .Will prob post some pics once I'm right into it & no doubt you'll get some more questions from me yet.
CHEERS Pete.
FC-V8
Hi Pete
     A couple of questions for you:
What part of OZ are you in ?
What type of v8 & running gear are you thinking of installing ?
Glenn
0401-065-201
pete
Hi Glenn , well i'm from little old Tassie and at the moment the motor will be a holden 8 with auto not sure about the diff prob. commodore. Won't put too big a donk in it , it will mainly be a Sundy cruiser with that sweet v8 sound.
Cheers Pete
