Injected V8 FC
Started by brett_f, May 29, 2008, 08:23:26 PM
brett_f
Well the time has come to upload some more pictures of my project. Been a bit slow progress lately due to the cold weather. The pics show the actual wheels i will be using and mods that i did to the original UC torana front stabilizer to clear the ring gear cover and the completed rear exhaust. For something different i have replaced the VT front brakes with VE front brakes which have brought the wheels in approximateley 10 to 13 mm c/o my step brother who is making kits to suit early holdens. The car is current in getting the wiring done for the computer so i expect to be able to start it shortly. Will keep you all posted.
regards brett
FC0058
Hi Brett
Your car is looking good, keep the photo's coming.
Cheers Jim
propig2003
just a short note, i was running a turbo 350 in my ute along with a 400 chev. setup now changed to 4/71 blown 350. tunnel was original when conversion done back in the 80's, now with updated info played in no small part to mark shearer of shearer bros. race cars, original tunnel is not adequate enuff for cooling around the auto. hope it doesnt fry. might b betta being safe than sorry, dude
propig2003 The stall are you running in the converter has to be considered in the equation, we all know that a big stall will create a huge amount of heat and heat is the main reason for failure of the transmition also available are the HI TEK BM coolers with fan mounted that seem to work well......FC427.......
propig2003
as well as the angle of the tailshaft which could put extra pressure on the front uni. there is a lot to consider when deciding to stay with the standard tunnel
cruiser056
Hi, Very nice car!!!  All the time and work will pay off when you first drive it.  It will definately be a head turner, for sure.  Can't wait for more pics.
All the best
Michael
brett_f
Propig,
Thanks for your concerns but all things have and were considered. There is plenty of room around the gear box. The exhaust is away from the box and i have a large trans cooler fitted. The angle of the motor is safe for the tailshaft and this is evident in previous photos, However if you also look at the photos i am running a two piece tailshaft. I dont know what you did with your vehicle but i have never had over heating issues with large boxes in small cars. I have had numerous LJ toranas fitted with 308 and small block chev motors with turbo 400 boxes and large stall converters with no over heating problems providing they are adequately cooled. Problems happen when you listen to people who have no clue themselves. If you were using the original FC or HR front end i believe the angle of your motor using a turbo 400 and standard tunnel would be too great causing major problems which you obviously had.
Regards Brett
propig2003
FE350
Very very nice work and great ideas brett_f, looks like it will be the best handling fc around,, is the LH torrie front the same track (outter hub to hub) as the fc?
brett_f
Thanks FE350.
The Torana front end is approximately 18mm wider each side. However, the new VE brakes bring it closer to the FC width leaving about 8mm wider each side than the FC.
Brett
ratbox
i always thought that commodore rotors pused the wheels out further, or is it because they are the VE ones ? useing the torana front does this sit the cat lower, in yor pics does the car have standard type springs or lowered thanks
brett_f
Ratbox,
The VE brakes have had the hubs modified to allow the wheel to sit in further (approx 10-13 mm). The front springs are slightly lowered to give the height that i wanted. For those following this build i started the motor for the first time yesterday and the twin system sounds fantastic.Nothing quite like the sound of a V8. The only hiccup was that the new radiator leaked from the tank seal. Not happy.
regards Brett
ratbox
thanks i'm thinking of doing the same front end in an EK
slack one
nice ride. iput a lh torana f/end under my fj.i am going to use the f/end  under another car.need to know where to get adt to fit ve disc.thanks gary
brett_f
Gary,
send me your phone number and i will get my step brother to call you regarding the VE brake set up and cost.
regards Brett
slack one
hi. brett my mobile no is 0401576179.thanks gary.
slack one
hi brett. your step brother rang me and i am going to meet in soon and see how it all works for my car.thanks for your help gary.
Chris5.7ltr
Love the build so far!
This is the first time I have seen someone use a Torana front end but it makes sense already having the Rack N pinion steering and pretty good handleing.
Did you narrow the Commodore diff?
Love your work, keep the updates coming!
brett_f
Chris 5.7,
Thanks for the kind words. Yes the commodore diff was shortened by Mc Donald bros who i would never use again due to poor workmanship but that is best left for another day. For those who are interested the FC Car Club is having a garage run in the western suburbs to inspect a few cars which includes mine. For those that are interested in the mods i have done to the vehicle, you are most welcome to attend. The date i believe has been set for the 23rd November.Please keep a watch on the site or news letter for the time and address.
Regards brett
kramsv8
looks great brett  8)
love your work
