FCRB30 Wagon
Started by pedro, May 16, 2008, 11:13:43 AM
QuoteI say if I took mine out long term he would just over take my side of the garage with all his junk.
It's not looking too clean out there at the moment :o, wait till Keith starts bogging and sanding then you won't want your car in there ;), and don't worry Mez is always on to me about why her car has to sit out in the weather while mine takes up the whole shed.
                                            Pedro
Haven't achieved too much lately this bog work seems to be taking forever and I've been doing some reno to get some dollars together for the old girl.
She's had a shunt in the rear at some point and it's been a drama trying to get it straight.
                                    Pedro
Pedro,
Good to see that you are still making progress, well done, keep up the good work.
F4+ ;)
Great work Pedro, try not to "ball up" too much though  ;)
Looks good Pedro,this part is not a lot of fun either but good to see you are still progressing.Jamie
QuoteGreat work Pedro, try not to "ball up" too much though
I'm definitely not having a ball that's for sure ;), started seeing the light at the end of the tunnel though today, just hope it's not that train again ::) ;D, organised for Gavin at retro rods to knock me up a new subframe piece today (the section under the radiator), so I'll be able to finish the welding on the front end and get it on next.
             Pedro
WOOHOO ;D ;D ;D, back in primer at last ;D ;D
Now for the front end, had this made up by Gavin at Retro rods, top bloke, hadn't spoken to him for a year when i rang him, he knocked it the next day and only charged me $20
He has now moved into a new workshop in town, these are the new numbers and e-mail address.
                    Pedro
That didn't work out too well the pics were too small and the reverse order, I gather i need to upsize them, what size should i use, I redid these through photobucket for now
GO PEDRO Just a little more and your ready for paint ....but please double check your repairs before you go to the next stage ...take a 1/4 sheet of news paper put it under your hand [makes feeling imperfections easy] and just feel all the panels again easy to fix now if you have overlooked and small marks before you move on to the painting  ::) ::).....FC427......
NosFEratu
You do realise that's gonna stuff up your power to weight ratio!  ::) ;D
Looking good Pedro - keep it up!  :D
NosFEratu
jack_fc
Great stuff, Pedro!
The primer might be Grey, but it's looking more and more like Orange to me  ;)
QuoteGO PEDRO Just a little more and your ready for paint ....but please double check your repairs before you go to the next stage ...take a 1/4 sheet of news paper put it under your hand [makes feeling imperfections easy] and just feel all the panels again easy to fix now if you have overlooked and small marks before you move on to the painting   .....FC427......
Thanks for the tip Mark, I'll do that, then if I'm correct i block sand it all, apply spray putty to the panels, block sand and reapply again over and over till I'm happy :(, then primer and block sand again, then  i can  put some paint on :)
QuoteYou do realise that's gonna stuff up your power to weight ratio!
You mean all that bog is gonna weigh her down ;D ;D
QuoteThe primer might be Grey, but it's looking more and more like Orange to me
Do you think Stinky might have some grey upholstery to go with it ;) ;D
                   Pedro
Found this article about the RB30 engine I'm running in an old holden mag. apparently 600hp. single turbo, 700hp twin turbo, from what I've been told even a mild turbo setup gives more power than a 5.0ltr. V8, Hmmmm veeery interesting ;D ;D ;D.
                             Pedro
Pedro 700 HP easy they have screwed over a 1000HP out of them ......700 HP in a car that will weigh in under 1250 Kg :o can you handle it will be the question on everyones mind  ??? ??? ??? better go with a 9" diff  :P.......FC427......
Quotecan you handle it will be the question on everyones mind
Let's just say I'm better at it than sanding back bog ;), spent most of my life on high powered bikes and cars, and I LOVE IT ;D ;D, seriously though i was only thinking of the standard RB30 turbo setup that would be enough in such a light car.
                 Pedro
NosFEratu
Quote from: pedro on October 16, 2009, 03:22:29 PM
I was actually referring to the fact that the piece of metal you had bent up for the front end would ultimately decrease the power to weight ratio that had been gained as a result of the car's overall mass being decreased through the unique factory oxidisation process in the last 50 years! But yep, bog'll do the same thing too!  ;D
NosFEratu
Pedro,
Remember that bog is not as heavy as the lead that they used all those years ago.
After seeing some of the custom work that they used to to do years ago, I wonder if the term "lead sleds" came from the fact that they had quite a lot of lead in them.
With that in mind, good to see that you are using the lightweight alternative, so that the power to weight ratio isn't altered to much ;D
F4+ ;)
smithy
wooohoooo, go pedro go !
looking good there mate  ;)
those RB motors can punch out quite a bit boogie, and you can always look at fibreglass guards / bonnet if you need to redistribute some of that weight. and with the jap motor,
fibreglass has proved a big hit with the ricers  ;) ;D ;) ;D  ;D ;D  :-*
jack_fc
Pedro, back when VL turbos were first released, the local Holden dealer insisted I test-drive one (he thought I was a 'petrol-head'; the poor misguided man...)
It went like the proverbial just-neutered feline (for a 'standard' Commonbore; which it wasn't - someone at the dealership had had a little 'play' with it in an underhanded attempt to impress unsuspecting prospective customers)
And even if you do add a little weight to the FC, it still will be shitloads lighter than a VL!
I'll gladly drink rum with you at Orange, but you've got no hope of conning me into any bets involving bottles of rum and 1/4 mile times  ;) ;D
Thanks guys, been busy wrestling with the radiator to make it fit and welding up the front end, the old 186 used to make the FC go pretty hard so i think I'd have to make the whole body out of lead before weight became a problem for this motorengine ;), as for the turbo version It's probably overboard but it's good for a bit of SCW posing when the bonnet get's lifted ::) ;D ;D
                                   Pedro
