What is a good distributor for a 308
Started by fc_clint_nz, April 02, 2008, 06:32:06 PM
fc_clint_nz
I have been looking at these pro comp hei dizzys but then looked at a compact one not really sure what i should use. Any ideas or advice from you guys would be great. Cheers Clint.
NO NAME
smithy
hi clint, i was looking at some procomp coils a while ago and asked same question here. might pay to do some research on these .
this is some of the responses i got
http://fefcholden.org.au/forum/index.php/topic,12709.0.html
similar sort of reponses on other forums i checked out aswell.
in the end it basically came down to you get what you pay for!
hope this helps in some way
dean
Revhead_Fc
Hi Clint Mate if you can i would try and source an electronic one from a VK commodore i think VH's had them too you cant go wrong with a factory electronic unit unless its going into a highly modified motor then i would look into brands such as mallory or i think even msd do 308 dizzys now i put a procomp dizzy setup in my torana a few years ago and had nothing but dramas
Hope this helps
Ben
fc_clint_nz
Thanks guys for the good advice, i think i will spend the extra $$ and get a good brand, those pro comps seem to be popping up all over the place and they are cheap so i guess you get what you pay for. Cheers Clint
