very diffarent
Started by Damo58, March 30, 2008, 05:28:10 PM
Damo58
Iam good just ask me :)
The item is a Tawco  combination inlet and exhaust manifold to suit Holden Grey powered boats, the Tawco units enable the manifold to be used as either a single carb or triple carb setup depending on the requirements of the owners. They are water cooled to prevent too much excessive heat when used under the engine covers. They were made in Victoria.
Other parts that you may see from time time is water cooled sumps, and cylinder heads that have been drilled  and tapped over the exhaust valves to enable a manifold to be screwed onto the head to assist in getting the hot water away from the head. I have also seen flywheels that have had most of the flywheel machined away leaving little more than a place for the ring gear. (for racing boats with direct drive)
F4+ ;)
Small world I have just listed on ebay a TAWCO Red Motor marine conversion last night also can run single or twin carby item no 200211812829 take a look ....FC427......
NO NAME
why didnt you say something mark, a mate in newcastle is chasing a conversion kit for a red, he just buaght a boat without the stuff but was running a red and he wants to put in a red and supercharge it.
i have a grey tawco clutch in my cabin cruiser wich is slowly dying.
FCCOOL it comes and goes and most of the time I don't get to ebay it,  was just that I read the TAWCO post and replied other wise would not have mentioned it. Why didn't you tell me your mate was after one ????? if you want to check it out for him let me know.......FC427......
NO NAME
Quote from: FC427 on March 30, 2008, 09:39:58 PM
yeah i just sent him a email.
