EffCee has an FC
Started by EffCee, March 08, 2008, 10:41:32 AM
Here is picture of my FC. This is what it was like when the previous owner bought it. This photo was taken by the previous owner. It is now totally stripped and I will be picking it up in the next couple of weekends. There is also another FC for spares. I will post pics of the car after I pick it up. i will also post details of the numbers for Ken. I haven't posted photo's on a forum so I am hoping this works.
F4+ ;)
I posted the photo, but the photo is quite small, any Ideas on how I can make it bigger?
F4+ ;)
ridgey_didge
You need to buy a bigger car next time - this one should be in the model car section it appears.
David
fc_clint_nz
You have done better than me i can't even get a few pics up. ???
You have linked to a thumbnail size image.
As you are using 'webshots', click on the "link to it" button on the right of your image in webshots. This will open a new window with preset links.
In the new window, change the size to 600 pixels and use the post in forum text. To do this, simply click on the text, them right click, copy, then paste into FE FC forum post.
Car looks like a good start.
Looking forward to seeing the updated pics.
Thanyou for your help Custom FC, It was much appreciated. After playing araound a little I was able to move the picture into my avatar. Thankyou very much. ;D ;D
F4+ ;)
I bought my car home a few weekends ago. The previous owner (Corm) had stripped it down to a bare shell and cut some of the LHF floorpan out to remove the rust. There is very little other rust in the car.
The car is now in the garage and work has commenced. I will be posting more photos soon.
The plan is to put a hot grey engine with triple carbs, Holden depress gearbox, HR front and rear end. When I bought the car included was a EK auto transmission tunnel. This will be welded in at the same time the new floor pan is welded in.
I am hoping to have the body prepared for paint by the end of June, Painted by Mid August and completed by Christmas ;)
F4+ ;)
NosFEratu
Hi EffCee
Good luck with your project - keep us informed of your progress.
Kathi  8)
NosFEratu
Paul In Ireland
Much as I would love to do that - I will buy an already restored one in the best condition I can get.
smithy
geez keith when you said it was in pieces you weren't mucking around were you ;) ;)
QuoteThe plan is to put a hot grey engine with triple carbs
are you sure, or maybe a grey motor ;)
or maybe the other,
come over to the dark side, you know you want to dont you ;D ;D ;D ;D ;D ;D
i promise i wont tell ;) ;) ;)
Quote from: smithy on May 03, 2008, 08:20:25 AM
or maybe the other,
What Smithy is referring to is the fact that I have been given (gratis , for free) a RED engine. Not only just a RED engine but a reconditioned speedway engine, you know all the fruit, hi compression pistons, star fire rods, stage 5 yella terra head with roller rockers etc. It is so tempting to put this engine in, especially when I don't even have a Grey engine at the moment....  :-\
I really would like a Grey.... :P
F4+ ;)
NosFEratu
Hi EffCee
A can of paint will give you a grey!  Why not - if the truth were to be known, NosFEratu actually has a black motor!
Kathi  8)
NosFEratu
I have been busy since my last post, I have been sorting through the nuts and bolts, some were bagged from the previous owner alot were at the bottom of boxes, It is difficullt working out where nuts and bolts go when you haven't pulled the car apart, but have pretty much got there and have them all sorted and labelled
I have also been cleaning up the door internals so that after it is all painted it is easy to reassemble. I do this in the evening when I can't make much noise with power tools. Once I have finished with the door internals then I will be starting on the HR front and rear end. This way after it is painted it will seem that a lot of work has happened in a short period of time.
I have also mounted the car on a rotisserie to make it easy to work on. It is so much easier to work on and the time that it took to make the rotisserie will save time on the ong run. In the clean up i have found that there is a few more rust spots that I didn't know about but I think that this is nearly always the case and these will be dealt with as I get to them.
At the moment the intention is to remain head down and bum up so that I can complete the car by Christmas. I will post photo's later.
F4+ ;)
Paul In Ireland
Ah Kieth! Now you've stuck your head above the parapet, the black beast with the Henchmen will keep coming weekly for updates.... 8) 8) 8) 8)
You could have stayed low and quiet, but no, you had to stick your head up for a bit of fresh air!
Sundays it is - and don't get too nervous.
NosFEratu
Good to see your report Keith - even if it is a little late.
Obviously you have taken heed of my comment in your other thread and acknowledged that the updates should be posted here!  You can back off for the moment henchmen!
We know exactly what it is like trying to sort through a jigsaw without the box - went through the same thing with the 58!  Keep up the good work Keith - preparation and knowledge will be the key to your success!
Kathi  8)
F4+ =^^=
NosFEratu
Good to see someone is getting something done, are you still going grey or have you given into the temptation and decided to run the red ;).
                     Pedro F4+
Pedro,
As funds are short, and I have a red sitting in the floor that just needs to have the sump changed, and I don't even have a grey motor yet, I have given in to temptation and will be using the red.
That's not to say that there won't be an engine change later ;) I still love my Greys
So it will be Red motor, M20 gearbox, HR (disc) front and rear end, K-Mac suspension, dragway wheels (7x13) Original type interior in the blue and black, and fountain blue over skyline blue in the early 59 FC paint style.
F4+ ;)
I have just realised in my first post on this topic that I said that I would post the numbers for those that are interested, I am sorry for not doing so earlier.
The numbers are as follows:
Chassis FC-33903-S
Body FC225-19452-S
Trim 277-629
Paint 253-0700
Insert 256-7770
F4+ ;)
Just an Update
This week I have been cleaning all the old paint off and the mud and crud from underneath the car. I have found a few more rust spots but these are only small and wont take too much to repair.
I have been head down and bum up and I am still on track for getting the body prepared for paint by the end of this month and will be taking three weeks off in July to ensure that in have the painting done be the end of August.
Still no photos but they will come
F4+ ;)
NosFEratu
A++ for getting your report in early this week Keith!
And remember, any progress is good progress!
Kathi  8)
F4+ =^^=
NosFEratu
