trims
Started by rat, June 19, 2007, 11:26:43 AM
rat
thumb prints wheel trims are they hard to find and what are they worth as i am after a set for my ute can get 3 but would need 1 more
cheers gazrat
FATBOY
talk to slim hes always got a few lying around
cheers fat
fatboy
0414712441
REDMR2RED
Not wanting to steal your thread, but as you're only after one Gazrat, I'm after a set of four.
If there are any more out there, I would like to hear from you ............. after Gazrat of course.   ;)
Cheers, Kevin
1959 FC Holden Ute
Be aware that there are 2 types - small thumb print FB/EK and large thumb print EJ
Regards Ken
HAD 708
And also be aware that i have purchased 3 sets over the years and since sold one set to a forum member and they are pricey! But they are worth it as i think they look the goods on a stock car Good luck with your search as they are a little like hens teeth!
Brett
Brett Gillard
Rabbitoh
A photo here would be great for those of us who are not sure what these actually look like ;).
Fortius Quo Fidelius 1966; Saints' 2nd in 2027?
Bunnies' 22nd in 2027?
REDMR2RED
Rabbitoh, check out Accessories No 32. Wheel Embellishers
http://www.fefcholden.org.au/cgi-bin/yabb/YaBB.cgi?board=nasco;action=display;num=1129558690
Ken, I thought the thumb print Wheel trims were for the FE or FC.  If not, what should the FC have as wheel trims?
Kevin
1959 FC Holden Ute
Or this one, #40 from Alex's great reference list.
http://www.fefcholden.org.au/cgi-bin/yabb/YaBB.cgi?board=nasco;action=display;num=1134387905
I think these are harder to find than the thumbprint type & like the thumbprint type, there are other types that look similar.
Gary
Absolutely Gary - these are the genuine FE and FC wheel trim rings.  The thumbprint trim ring was released in December 1959 which means that barely any FC's would have been fitted with these from the dealership.
They are a little more common to find than the early ones because they clip on behind the hub cap whilst the early ones were a push on stle ring.
